Hello,
I need help hooking up a gas gauge on my 1947 M5 pickup. The gauge currently sits at full all of the time. I replaced the sending unit and verified that the wires are not broken from the sending unit to the gauge. I have a replacement gauge as pictured below, but I wanted to first verify if the current gauge is just not hooked up wrong. The current gauge has a wire attached to the "IGN" bottom terminal. From what I could see crawling under there is also a wire on the "1" left terminal. I don't see a wire attached to the "2" right terminal but I can't confirm that as it is pretty difficult to get under that dashboard. How is the gas gauge supposed to bee hooked up? What wires hook up to terminal 1 and terminal 2?
