I searched all the threads here relating to this subject and could not find the answer to this question, so I will post it for some advice.
I check my gauges as I drive pretty regularly. (I also drive a school bus now and then and that is part of our training). I do not remember my ammeter showing any significant discharge at idle when I had things turned on such as lights, fan, or windshield wipers. On Tuesday of this week I had to replace a completely dead battery. I mean this poor things was profoundly dead. I replaced it with the correct battery and the truck fired right up. I drove the truck to work the next day. It was dark and raining so I had all three of the items listed above turned on. I watched the ammeter closely and noted that at stop lights when the engine was at idle the ammeter showed a discharge of about 25+ amps. When I revved the engine the needle shot back to a positive charge of nearly the same but settled back down fairly quickly to about 3-5 amps (estimate). I do not remember that much of a discharge at idle before. When I turned everything off but the engine the ammeter showed a discharge of about 5 amps, which seems reasonable. The truck still has a generator, not an alternator.
It may be that this is perfectly normal and I need not be concerned, but I thought I should throw this out here and see what you guys think.
