I know there is a way to tell by turning one wheel when it is up on blocks. Is there also some identification on the unit
TT how can you tell
Tags: None
From Bob's website:
If you find a tag on the cover plate with 45B, this will tell you it is a limited slip (Twin Traction) rear end (not a 45 axle). Early Twin Traction Axles used a axle cover tag with a large T on them (they
had a 30 degree ramp angle).
A 45 "C" is a Dana 44 with the Limited Slip. A Limited Slip differential is denoted as a "45" and the "C" is the type of Limited Slip" clutch assembly.If you look in your Studebaker shop manual it shows the different clutch packs and their letter designation.
Tags also were on the axle cover plate, with the rear end ratio listed.
Axle model #'s are cast on the housing, just around the corner from the filler plug. Spray some engine gunk on the axle and take it to a self service pressure car wash to clean it up.Dean Seavers
Sacramento, CA
Be careful to not misunderstand this one:
This will ONLY tell you if it is a 23, 27 or 44 though, as a 45C (TT) or whatever Alpha, is NOT noted there.
The "Other" method to tell a Standard Open rear end from a TT is, just pull the Fill Plug and put your finger in there, if you feel the Twin Traction Case very close to the Cover it's a TT.StudeRich
Only ONE way to be 100% convinced...remove the housing cover and look.
Every other way can be off, in one way or another.
I've seen loose posi unites and very tight open carriers...they can fool you.
Plus, that provides a great excuse for changing the axle oil, which very few people ever do..!
Originally posted by TWChamp View PostI've worked on GM cars with posi-traction, but never had the Studebaker Twin Traction apart. Are they different?StudeRich
Since it's been brought up: the rear end of my '59 Lark wagon (currently out of the vehicle) is a 44 TT unit. I was surprised when, with the pinion yoke held stationary, turning one axle made the other rotate the opposite direction- I thought that was characteristic of an open differential. Does that suggest worn clutches or...? It's got about 120k miles on it, yet the teeth all look clean & sharp w/barely any detectable (and quite fine) shavings in evidence. Thanks for any input you might have...
JSC
Originally posted by Play Wagon View PostSince it's been brought up: the rear end of my '59 Lark wagon (currently out of the vehicle) is a 44 TT unit. I was surprised when, with the pinion yoke held stationary, turning one axle made the other rotate the opposite direction- I thought that was characteristic of an open differential. Does that suggest worn clutches or...? It's got about 120k miles on it, yet the teeth all look clean & sharp w/barely any detectable (and quite fine) shavings in evidence. Thanks for any input you might have...
JSC
When I asked if the GM posi was different, than the Twin Traction, I was wondering if the TT used clutches and springs or some other method to lock the axle?
Years ago I read an article about a locking rear end that used worm gears and no clutches, but I don't know if it ever got into production, or only as far as the design table.
Originally posted by TWChamp View PostI'd check the spring pressure and clutches for wear. We always added special lube for posi-traction units when I worked at the dealership. I wonder if your rear has the correct gear oil?
The Stude twin traction uses a tapered ramp on the spider gear cross pins to load the clutches. The alternating clutches are slightly conical to engage more smoothly. The easiest way to tell if you have a twin traction is by removing the filler plug, and sticking your finger into the hole. An open carrier will be hard to touch as it doesn't fill the case well. The twin traction is larger, and you won't be able to stick your finger past the first knuckle.Bez Auto Alchemy
