View Full Version : 59 Lark Station Wagon drivers side molding and Clips
007
10-23-2016, 01:26 PM
I am assembling my 59 two door wagon(only made the 2 door in 59) which has been apart for 19 years and I am missing some parts. Can someone help me on these two items. #1332171 and #1332191 which is driver side molding pieces after the door to the rear of the car. Also I am worried about corrosion of the clips #801884 kit is there an after market stainless replacement? Everyone of my original clips is rusted and useless.
Secondly trying to identify the part number for the clips on the 59 wagon that hold the jagged pieces that hold the headliner in place???????????
Regards,
Mark
10-23-2016, 03:33 PM
Mark, in the 801884 Moulding Clip Kit, you get (7) 1332472 and (52) 1332473 Original, painted NOS Clips, if you want Gold Plated that will cost you! ;)
Warren Webb
10-23-2016, 09:33 PM
If your worried about the clips rusting you can always dip them in POR15 by a wire with the molding side down. Wear gloves if you do. That stuff doesn't wash off with lacquer thinner & cover the floor with cardboard underneath.
Mike Van Veghten
10-24-2016, 07:49 AM
007 -
Naaa...or my 60, 2dr. wagon is from another planet. I believe there were a few 61's also. Yes, the 59 and 60 side panel trim is slightly different if that could be what you are referring to...
That's along side the 54 and 55, then into a couple other years I believe.
jackb
10-24-2016, 08:17 AM
If using NOS, make sure you are not installing over 3-4-5 coats of paint. They will not stay inserted through the thick paint...
007
10-24-2016, 04:38 PM
Heh lucky me I was able to pick up today the driver side molding. Okay so I will order the clip kit from S.I. and paint the clips.
Still trying to find out a part number for the clips that hold the headliner jagged pieces inside.
Regards,
Play Wagon
10-27-2016, 10:33 PM
007,
According to the factory parts catalog you might be looking for clip #1332437. Good luck...
JSC
Buzzard
10-30-2016, 11:30 AM
Hey there 007. I would like you to post the Vin# and any other pertinent information for the '59 Lark registry I'm compiling.
Thanks in advance,
Bill (Also in BC!)
2R5
10-30-2016, 11:36 AM
Are they not the same clip as the 60 molding used ?
007
11-04-2016, 11:39 AM
Heh Buzzard the VIN number on my 1959 wagon is 59SC-5343.
Regards,
Mark
Tiggum
11-04-2016, 11:46 AM
Far clarification, the 1959 Lark 2 door wagon was the only year available as a Regal and as a Deluxe; in the later years, available as a Deluxe only.
007
08-26-2017, 12:40 PM
Just a note the new repop clips are not exactly like the originals-so modify I guess thanks.
Regards,
007
