I have an oil filter for my Champ PU. that is the screw on type for the overhead 6 cyl. What I am trying to figure out is what is the length of the oil Line and or the part no. Would anyone have a picture or diagram that would help me mount the bracket and fittings?
Oil Filter
If you Mount or Temp. position the Filter Base and mounting Bracket on the Cyl. Head you should be able to measure to the 1/8 Inch Pipe Plugs on the left Side of the block the lower one is Drain back, the upper one is Oil Pressure (Inlet is outer Hole in Filter Base).
Your Auto parts Store will have the 3/8" High Temp. Oil resistant Hose to make the lines with proper fittings.
These are a piece of Cake to Install.StudeRich
