How do I look for a switch ignition wire ? I'm trying to hook up a blue tooth audio integration & origination , their calling afor a switch ignition wire.. Thanks mike
How do I find a switched ignition wire?
Tags: None
I use a small 12V test light. I put the car ignition in the "on" position then use the tip of the test light probe to find the pin that has 12V. Now remember one pole will be hot even when the ignition switch is "off" (that one goes to the battery).
treblig
Originally posted by 14x7 View PostThis is a 55 president , 6 volt battery, I think the ignition switch was replaced.
I forgot to mention, when using a test light ALWAYS start by touching it to the battery to be sure it lights up. My 50 Champion is my only driver until I can get my newer Olds running again. The other day I was stumped on why the fuel pump relay wasn't sending voltage back to the tank..........only to discover the light bulb in my test light wasn't lighting.
You should hook any audio device to the ACC terminal on the switch, not the IGN. That way you can listen to the radio without burning up the points, or the old Pertronix.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
My President didn't come with a radio , and no Pertronix , just points and condenser. No stereo either .. Just mostly stock...Maybe I'll call the company and ask if that would be ok ,to hook it up to the Acc terminal ....
Of course it will be OK, why would you or "they" want the Engine to be running to turn on a Radio?
I just rented a 2016 Nissan Altima last Month, and even with the "New" "Start" push button, you had to quickly Tap it to get to Accessory Mode to listen to the Radio, so that tells me that every Car on the road has their Audio System wired to the Accessory Terminal of the Ignition Switch or whatever poses as one.Last edited by StudeRich; 09-26-2016, 09:45 PM.StudeRich
The accessory terminal is where the radio is supposed to be connected. That's why they put an accessory terminal on the switch.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Originally posted by TWChamp View PostBTW, Harbor Freight sells a nice quality test light for under $5.
Originally posted by 14x7 View PostHow do I look for a switch ignition wire ? I'm trying to hook up a blue tooth audio integration & origination , their calling afor a switch ignition wire.. Thanks mikeOriginally posted by 14x7 View PostThis is a 55 president , 6 volt battery, I think the ignition switch was replaced.Last edited by wittsend; 09-27-2016, 01:37 PM.'64 Lark Type, powered by '85 Corvette L-98 (carburetor), 700R4, - CASO to the Max.
