Does anyone know if a template exist for installing a the rubber fender aprons on a 53-55 coupe. Mine is completely gone,and I want to install new ones. Also, many dealers installed accessory mirrors on doors, I would think that they would have used a template to install them in the "best" place? I would like to have access to both templates. It would be great if SI, and other suppliers would include a paper template when these items are purchased.
installation templates
Tags: None
Not sure what you are asking for. Fender liners, as on todays cars weren't installed on your car. There are some fender to cowl splash guards see :
The reason they appear missing is, that they weren't there.
Mirrors were mostly dealer installed-often by "where they looked good"--leading to a mixed bag of placements. Exterior rear view mirrors were, at the time, not a required vehicle part by law, so most came without any. New owners who wanted them, either bought them and put them on themselves or dealers installed accessory ones. Lots of changes to automobiles since 1950s, lots and lots of government regulations came later.
Welcome to the forumLast edited by karterfred88; 09-16-2016, 12:13 PM.
body/ front fender rubber aprons
Originally posted by karterfred88 View PostNot sure what you are asking for. Fender liners, as on todays cars weren't installed on your car. There are some fender to cowl splash guards see :
Thanks for your reply. I am referring to the rubber splash aprons "stapled" to each front inner fender. Thanks again!
Originally posted by 5hawks View PostI am referring to the rubber splash aprons "stapled" to each front inner fender.
As far as the mirrors are concerned, other responses have been right on target. If you purchase external rearview mirrors, have someone move them around as you sit in the drivers seat and pick the most effective location, being careful to avoid interference from the wing vent window. There is virtually no way to make the passenger side mirror of any value unless it is one of the door edge mount type.Brad Johnson,
'56 Sky Hawk in process
Rear view mirror on wife's 57 Hawk is viewed through the vent window and does well. no R/S mirror. same for my 62 Lark, but it originally had a window frame mounted "Peep" mirror that worked well. this has since been transferred to my 53 Coupe "Hot Rod". sit in your car and have a helper hold mirror against door to find best spot to mount, you want them to be useful not just decorative. Luck Doofus
Some of the mirrors offered at S.I. have the option of a convex lens. If you buy a pair of those I would first have someone hold the right mirror in a position where you can see it well from the drivers seat, then mark the right door position & confirm with the drivers side mirror.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Originally posted by cjresto View PostI have additional question. Will be looking at same thing for my 52. How would you staple these on? Do you have to predrill the holes? Do you know if SI has the staples?
Thanks
Bill L.
1962 GT Hawk
Originally posted by rockne10 View PostEven if they are totally gone you can see the perforations where they were "stapled". I bought a set of the repros from SI some years ago and they were not really correct. I think they may have been copied from a set from a sedan. Even without a pattern they were easy enough to fabricate from scratch.
Thanks for your reply. On the rubber splash guard problem, the placement would be easier if the fenders were on the car using eh frame as a guide, but they they are much easier to install off the car. On the mirrors, I will continue to have a helper hold it in place while I remain in the car looking for the "best" spot to mount.
body (installation templates
Thanks
Many years ago when I restored my Speedster neither the rubber or the staples were available. I went to a rubber supply company for the material and used the original rubber for a pattern. Then using some fairly heavy wire, I threaded the wire through small holes that made by driving a nail through the rubber, and then through the original holes in the sheet metal. I then twisted the wire tight on the backside. When I finished the job looked close to original.
