OK, marked the caps, removed them, tried prying with a crowbar and tapping a bit (carefully avoiding any contact with ring gear, yes).
Not budging.
Are those rings (under the bearing caps I removed) just sitting in there, 'stuck' and will pull straight up? Or do they happen to overlap something that I might damage if I hit the crowbar any harder (putting it under the differential gears housing, solid sides).
Manual doesn't say, just warns against prying on ring gear. But I've heard of a "spreader" somewhere, and don't want to proceed unless I'm absolutely sure those are supposed to pop right up and out of there, and are just 'stuck"......
THanks!
PS: DID check ring-gear , movement? side to side per manual, 0.002" vs <0.003" spec. Hurray! About my luck lately for THAT to have been sprung or something :-)
Not budging.
THanks!
