my 1964 studebaker cruiser steering system needs tightening up. The shop recomends I replace the pitman arm on my cruiser. Perhaps I need to replace the bearings that are on the pitman arm. I'm looking for bearings for that P. arm and I'm looking for advice.
pitman arm bearing or bearings for a 1964 cruiser, studebaker
If the shop is not familiar with Studebakers, they may assume that you need bearings when all that you need is to TIGHTEN the cinch bolt and grease the bearings through a fitting accessed through a hole in the crossmember.Gary L.
The kingpins have bearings as does the bellcrank. The later is usually the problem since the zerk is hidden in the cross member and grease monkeys often miss it when they lube the car - or they under lube it and do not get grease up to the top bearing. They are an ordeal to change but if there is any movement in the bellcrank they must be replaced.
