I have a 1951 Starlight Coupe. All electrical items have been rebuilt or replaced except dash gauges. Car is 6 volt positive ground. I'm using a good condition Optima AGM 6 volt battery.
In the old days the ammeter used to show a discharge when operating light or heater, but swung to positive when rpms increased. Years later it would still show discharge, but stayed in the middle when the rpms were increased. Then when you would go over a bump then needle would swing to a significant charge. Lately, it shows a discharge, but doesn't appear to charge at all, or if it does it appears very minimal on the ammeter. Going over a bump doesn't cause a change anymore.
While the engine was running I measured the voltage across the battery terminals with two separate voltmeters. They both showed 7.2 volts. With the car not running the voltage across the battery was 6.6 volts, which seems high, but that is due to the excellent smart charger/desulfator that I keep connected all the time. As an aside, the one I use is made by BatteryMinder and it does a good job of restoring batteries that are sulfated if they are not too far gone. Good at preventing sulfation as well. Note: charger was not attached while measuring battery voltage.
One other thing. I just replaced the water pump and at the time I did not tighten the fan belt very much for fear of damaging the new water pump bearing. Maybe I should tighten that a little more?
One more thing: years ago I had a short that partially melted the plastic insulation on the fat red wire connected to the ammeter. However, car seemed to run OK after that. Is it possible the gauge got damaged?
Any ideas?
Any ideas?
