What is the proper procedure to check the automatic transmission fluid in a 51 Champion? For many other makes of cars in the 50's you would check the fluid level while the car is running and in Park, but I believe that is not the case with this car. Also what is the recommended fluid. I believe at one time is was Dextron III. Thanks for your help.
1951 Champion automatic transmission
Tags: None
Brad Johnson,
'56 Sky Hawk in process
Rather than just setting the parking brake, which works perfectly well, I also ease the nose in to a solid surface, just for ridiculous security.Brad Johnson,
