I have a '54 4 door sedan and the door post between the front and rear doors has a stamped out hole 1-1/2" x 4" complete with screw holes top and bottom with the appearance of accommodating a rear courtesy light. The rear door posts have a blank to be punched out for a courtesy light switch that I am going to install. The punched hole is under the upholstery, I discovered it when I removed the covering. Was there any models that had such courtesy lights? See photos.
courtesy lights
Tags: None
Originally posted by altair View PostI am going to fabricate a box to fit in the hole and wire it with a light, but if there was a factory light it would be a lot easier. David
There were never any "B" Pillar lights. I believe most of us agreed the last time someone found one of those holes that it was a Carry over from the days in '47-'52 when an Ash Tray went in that hole on some models.
The Medium and High Trim Level models all did have all 4 door Automatic Dome Light grounding Switches on the Hinge Pillars.StudeRich
