I just purchased a 57 golden hawk that had been restored a few years back and had only 2250 miles after the rebuild. It did not idle well so I added a cleaner to the fuel believing the carb probably needed cleaning. I then drove about 180 miles and found no improvement. It was idling at about 1000 rpm and if put in gear drop to around 400 and act like it was going to quit with very rough idling. Reading through the PO receipts it appears that during the engine rebuild an R1 cam was installed. Anyway today I hooked up a vacuum gauge which read 14 on the scale which indicates extreme late ignition. I then got out the timing light and found the timing was way off. I got the timing set, lining the pointer with the correct line on the damper and the engine now sounds better but the vacuum gauge is still reading about 14 and the idle which I did not adjust is at 900 but drops way down and still acts like it is nearly stalling when put in gear. If I run it up to 2000 RPM it seems to run good.
Could the vacuum reading be caused by the cam? Could the valve timing be off and how does one check that - I almost don't want to ask. Why would the rpm drop so much?
Engine was rebuilt by a Studebaker man. Super charger was rebuilt as well as transmission (auto).
