Hello Forum.
First time poster, long time follower. I recently replaced worn wire under the dash board with correct wire and connectors. All gauges were restored professionally and installed with care. Starter, generator, and distributor were rebuilt by skilled people as well and I have accumulated all-new-old-stock ignition parts ( it took me 20 years). The engine turns well, but won't start. (on the fuel side of the engine, everything is triple check perfect as well as the timing). A picture of the rear of the instrument panel and of the fire wall for a guide to where the correct wires are connected would GREATLY help me complete my project ( ignition switch wiring, voltage regulator, ignition coil set-up in exact pictorial detail). I have original wire diagrams but photos would help me out a little more.
Thank you,
Bernie
Thank you,
Bernie
