I searched the forum looking for info on torquing the rear axle hub nut on my 49 2R5 because page 150 in the shop manual says 120-130 ft lbs, but the torque chart in the back of the manual says 240-250 ft lbs. I found a post from Robert Crandall from last September that has raised another question. Why no grease on the shaft or bore? Is there really a chance of slippage, straining the key and keyway?
Rear axle torque and grease
The hub needs to go on dry. If you grease it the hub will crack. I have a torque wrench just for that because mine are spec'd to 175 ft/lbs59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
