Well I know it has been a long time since I have posted anything but I have been working a LOT on my 56 Champion 2dr.
To give some idea. I have taken the engine out. Bought a new one from SI. Painted to the correct colors. New Pressure plate, Clutch, and throw out bearing. I also painted bell housing to match engine and recent rebuilt transmission.
I took the front suspension out and replaced ALL of the bushings. I put New springs from SI and new shocks. Repainted all components.
I also ground down the Engine cradle, transmission cradle, and frame rails to bare metal and repainted semi-gloss black. I also painted the firewall black.
I have rebuilt and painted the starter and Generator to original.
My question is on the steering gear box I replace a leaking seal behind the pitman arm and a new gasket on the opposite side.
The lubricant was dark black and thick. Is it an oil or grease? The shop manual calls for Kendall 400 or Kendal 200 alternative. My local guys are not sure as to what that is.
Where do I get it and how full do I fill the unit.
I have gone this far and I do not want to do anything wrong at this point.
Thank you for any help.
