found 56 ph needing help with ID.body tag has 56B-C3 350 the second tag has C3 2 tone, the door tag has, 8430090 with a motor stamp is V364658, casting # is 536601, he said that is all original it does look complete thanks
56 Power Hawk
A 56B-C3 is a 1956 Power Hawk coupe. The 350 indicates that this is the 350th body of this type welded up, out of 7095. 8430090 is the Serial Number and indicates that it was made early in the 1956 model year in South Bend, IN and it is part of the Commander series. The V indicates that the engine is a 259 cid. You can go to the SDC home page to check if the engine number is in the correct range for a 1956. It is unusual to have a second tag (streamer) to indicate a two tone paint job.Gary L.
The only reason I can think of is, the Body Line employees sometimes must have needed a prompt to remember to drill the Holes for the around the rear Glass Two-Tone Stainless moulding before Paint.
A Two-Tone Paint job would be no big deal to remember and easy to fix if wrong, but No Mouldings to hide the paintline would be a bigger problem.
Maybe used on Monday Mornings!StudeRich
Originally posted by jetboat View Postthe car does not have the trim divider on the quarters,must be top only color
EDIT: Once again, Rich and I were "typing" similar replies at the same time. He just got his in one minute ahead of mine (probably due to dial-up).Gary L.
Very true Gary, my Comcast Cable connection is VERY Fast, and I can update them to add pics and corrections for about 5 Min. or more without a Updated Note.StudeRich
Originally posted by jetboat View PostI think the car is the same color as the coupe, but has 2 colors on top , the car is on craigslist corvalis in Oregon,too rough for my capeabilities and he is firm on his price of 5kGary L.
Originally posted by studegary View PostA 56B-C3 is a 1956 Power Hawk coupe. The 350 indicates that this is the 350th body of this type welded up, out of 7095. 8430090 is the Serial Number and indicates that it was made early in the 1956 model year in South Bend, IN and it is part of the Commander series. The V indicates that the engine is a 259 cid. You can go to the SDC home page to check if the engine number is in the correct range for a 1956. It is unusual to have a second tag (streamer) to indicate a two tone paint job.
