Hello Guys,
My name is Kyle just joined here @ SDC, I got a 1963 Studebaker Lark in on trade a few days ago and i am waiting to get it back to being a daily driver. So down too the issue at hand. my headlights seem to have a mind of there own when the car is sitting still engine not running headlight will come on and everything works ( except brake lights but ill come back to this) if you crank the car as soon as the car runs the headlights will go off and on randomly. First thoughts here was i need a dimmer switch, so replaced the switch same issue. so i started going over the wires. Wiggling the harness as i go to see if i can trigger the headlight to act up. Nothing, HOWEVER... if i wiggle the turn signal knob as if i was going to use a blinker the headlights act up. my questions to this are as follows
1. What could be causing the issue in the Steering column?
2. What would i be looking at for this type of repair.
Also the brake lights i havent gotten to work at all, maybe a new brake switch? or fix headlight issue and see where that puts me at with the tail light.
Thanks in advance and look forward to growing and learning here at SDC
