Speedway Motors has a cheap SS lined Master Cylinder...
Be aware there are no residual check valves in this unit (and no warranty or return privileges)...HTIH (Hope The Info Helps)
Be aware that it is for Disc Front and Rear Drum Brakes, so probably has no residual Valve in the Port for Front Brakes, does not work on full Drum Brakes.
As mentioned it is for a Ford or Dodge with the lines to the Fender.StudeRich
