After about a year, I am finally resuming some work on my 1918 house. Seems like every time some remodeling was done on the interior of this place, they added another layer over the top of what was already there. I completely rebuilt the stairs over a 2yr+ period finishing up last year. They'd been poorly hacked up more than once and the bottom section was really narrow (still is) but made worse by the nearly 1-1/2" thick walls that were 2 layers of drywall with a layer of 1970s paneling in between. Made the shoulder width going up about 2" narrower than it could be.
I could tell this same lamination continued at the bottom of the stairs into the surrounding walls and the ceiling. So, I didn't finish the edges as I was planning to strip down at least that room as well. And after this, I am done except to redo the small bathroom.
So a couple weeks ago I bashed out one wall that is shared with the bathroom and found the expected 2 layers of drywall with a layer of paneling in between. The bathroom was probably put in the 1940s or maybe the 1950s. Yesterday, I continued with 2 short sections of wall that are originals to the house. So, here the setup changed. The more recent 1990s layer of drywall, then the 1970s paneling. Under that was I think wallpaper (most had been ripped off to glue down the paneling). Under that was peeling pink paint on what I thought was more drywall. But, the stuff seemed to be in pretty small sections and may have had a skim coat of actual plaster over it. It was hard to tell. It was a lot harder than modern drywall that is for sure and a real bear to get my wrecking bar under. Then, under all of that was the original wall of tonque-in-groove planks that were painted a dark green. This house has no plaster over lathe so far I have found.
The pink "drywall" extended under the end of the bathroom wall so its older than the bathroom. I've done a little research and it seems these small early drywall panels maybe from the 1930s, at least prior to WW2 probably. One reference said they were 2' x 4' and had holes in them for that skim coat of plaster to adhere to.
My plans are to leave the original bottom layer of board planks and put 1 new drywall layer over that. It will still leave the room bigger by about 3/4" each side and the ceiling as well. I also need to properly fix the wall were a former chimney was and they did quite a hack job of covering over the area once it was removed.
