Grill Insert- can anyone help identify this??
Since they are wrong for Golden Hawk side grill Insert Trim, he could remove them if he does not like the incorrect look and be done, they could be for the '57 and '58 Stude. Station Wagon Valance (Shelf) between the Body and the Rear Bumper or another make.
I think Matt Burnett (a sometimes poster here) shortened some Wagon Mouldings straight and square, for the rear ends and used them as replacements on a Hawk.Last edited by StudeRich; 06-06-2016, 10:19 AM.StudeRich
Richard, you might be right on that i would like to see the back end of a 57 or 58 wagon to see if thay are the same length, as what i have these look like thay belong on the plate thow , drilled right & all ? some one may come up with the answer like the guy you said Mike Burnett , hope he jumps in , dannyo.
Richard , thay are not hollow in the center , if you can bring them up close on your computer you can see it is a doward dip in the center , like you put your pinkie finger in the tin is hawk, i took the old pot metel trim off this when i bought this piece it was broke , it think it is a mid year change ? i think i will see if Andrew beckman might shead some light on this to ,dannyo.
Originally posted by dannyo View PostRichard , thay are not hollow in the center , if you can bring them up close on your computer you can see it is a doward dip in the center , like you put your pinkie finger in the tin is hawk, i took the old pot metel trim off this when i bought this piece it was broke , it think it is a mid year change ? i think i will see if Andrew beckman might shead some light on this to ,dannyo.StudeRich
