Hi,
wrote and asked the shop my cam got sent out to (from person who supposedly was supposed to do everything but just farmed out all the machining and then had me pay him when I picked them all up).
The guy did write back from the cam shop, says: "Camshaft spec stock grind Ex and Intake lift on lobes 260 each Duration at 50 206 each mechanical lifters the black coating is to help prevent rust and help to hold the prelube".
the guy doesn't waste any words. :-)
He builds race cars with these other guys who did my block, crank, rods.... so I can only hope there is taper as well; (just got done reading a post about that being critical for keeping the lifters rotating....) Never thought 'make sure they did', again I'd hope that is standard for a professional cam shop, especially used to high performance engine work... How would you even measure that (I've installed the cam, but oil pan is still off til I get my new gaskets).
Probably too subtle to measure with a Vernier, maybe can't even get at it under the crank now to do so...
Guessing it is fine, but thought I'd ask about the cryptic 'answer' I got back on what was done to my original cam...
thanks
thanks
