The weirdest thing happened tonight while working on my 59 Hawk. I had the car running, set the timing and shut the engine down. Later I went to start the car and now the engine is locked up? Weird thing is, this is the second engine to do this in the car. The last engine locked up while in the car, but after removed, it was no longer stuck.
After I discovered the starter wasnt turning the engine, I tried to turn it by hand by pulling the fan blade while putting tension on the belt. It wouldnt budge. I then removed all the spark plugs and tried again. Still wouldnt budge. I then put the car in 1st gear and went to rock it to see if the motor would turn, but the car rolled forward just fine even while in gear?? Its a 3 speed O/D trans... is it supposed to do that? I dont think its in overdrive.
Could there be a possibility that maybe the transmission or something like that could be causing the engine to seem stuck? Like I said before, the last time this happened the engine unstuck itself after removing it from the car..
Any thoughts?
Any thoughts?
