I'm not looking for a fight here, and I don't want to be chastised for not conforming to government mandates. This is for level headed, thinking, information hungry Studebaker owners who are genuinely interested in enjoying and preserving their cars.
Ethanol enhanced gasoline is not good for your Studebaker. There are steps that you can take to slow down the damage that ethanol-enhanced gasoline is doing to your car such as rebuild your fuel pump with an alcohol resistant diaphram, and replace the soft fuel lines with alcohol resistant lines. You are not going to stop the alcohol from sucking up moisture and causing rust in your gas tank and destroying you tank-level float. And, you are not going to stop it from eating up the metal in your carburetor. I'm not going to go into a lengthy discussion of how I know these things, but what I say is true.
There is a way to protect yourselves. Refiners still make 'non-alcohol' gasoline. It's called 'recreational fuel' and it is 90 octane. In the past I had recommended that people call their local fuel wholesaler and ask which of their customers sold 'rec fuel'. Today there is an easier way. Some thoughtful fellow posted the address of an internet site which listed stations around the country on a state by state basis that sold it. It is quite comprehensive, and I thank him (although I already knew of several retailers in my area that sold it). It site becomes very handy if you plan to take your car some distance out of town and will probably need to buy fuel before you get home. Here's the site: http://pure-gas.org/ BTW, It is against the law to use this fuel on the highway. "Let freedom ring"~~!
