On an Avanti with p/s there is a rod and end that attach-es the bell crank to the p/s control valve.(1546218)
The end of the rod has a Zerk fitting on it..........my question is, the following; if that fitting does not get lubed very often how serious a situation is it?....That bugger is almost impossible to get access to!:-(
Second question: On the drivers side lower "A" frame.....is a bushing and grease fitting. For the longest time I have not been able to get grease into that bushing...........two different grease guns....I removed the Zerk and replaced it.....same situation......the bushing will not accept grease. Any suggestions?.....and how much 'damage' will be done if the lower control arm pivot pin does not see grease? Now understand this is only on the front Zerk, the rear Zerk accepts grease.
