I like this 61 Cruiser- looks decent as is, decent interior, and I like it in red! I was thinking about it as a beater, with an eye to eventually using the interior and drivetrain in a solid body in the future.
The problem with it is, the pictures show extensive bondo in the rear quarters[xx(] Someone bondoed the rear quarter seams over, including the area inside the trunk where you would access the bolts holding the rear quarters...
This looks like a quickie repair job that someone did just to get it going again. Whenever you put filler over rust, you will just trap moisture and hasten rust... it will look decent for a while, but will deteriorate pretty quickly and be worse than when you started! One picture shows the bondo already starting to fail... and Heaven knows what the rest of the car is actually like, and what the frame probably looks like...
I wrote this off as a car that's likely on the verge of coming apart; it may be better- or not. I'm saying be aware, and if I was serious I'd make the trip to see it in person. It's still worth considering; just don't want someone to buy it not realizing what's goin on.
Parish, central NY 13131
