Simple question.............when you work on your Avanti and the door/doors have to be kept open..........do you pull one of the battery cables so as to not run down the battery?
When you work on your Avanti.......
Originally posted by paintim613 View PostNot if you have switched off all interior lights first. At least not on my stock '63.
They have: ON - OFF - DOORS ON,
we have ON - OFF - and doors are always on.StudeRich
You win the big prize!!......I was going to suggest such a thing I finally did to my Avanti.......after 46 years of ownership..purchased these at York:-)Originally posted by rockne10 View PostHere's an idea I added to mine over thirty years ago.[ATTACH=CONFIG]53966[/ATTACH][ATTACH=CONFIG]53967[/ATTACH]
I would recommend a "Green Knob" disconnect on the negative terminal of the battery. It literally takes only seconds to disconnect/connect power. In addition to working with the doors/trunk open, it is also a good idea to disconnect the battery when parking the vehicle for an extended period since old wiring can sometimes do strange things.
I once had a short circuit happen in the dashboard of a '64 Daytona while driving. With the Green Knob, I was able to stop and disconnect power before losing the entire harness and/or the entire car to a fire. Note that it only takes about 1/2 turn of the knob to disconnect.
Jim Bradley
Lake Monticello, VA
'78 Avanti II
Working under the dash you better believe that I disconnect the battery. If I am just vacuuming out the car, no I leave the battery connected. Usually when my Avanti is in the garage the battery is disconnected. I don't need a car fire, as my bed room is above the garage.
Ron
