Last year we towed the 66 Daytona behind the motorhome using a dolly and taking the drive shaft loose at the differential. Took in car shows across the country including the St Louis International. Had admirers at all the RV parks and anywhere else we stopped. Traveled almost 6000 miles with the Daytona and no problems.
I would like to tow it on all 4 wheels this year with a high tech tow bar and not have to crawl under the car every time to hook up or unhook the drive shaft. I have the tow bar connectors for the car engineered and ready to build and install.
I've been eyeing the Remco drive shaft disconnect system and wondered if anyone has tried this on a Studebaker. This way all that needs to happen is to pull a knob to unhook the drive shaft and push it back in to re-connect. No more crawling under the car every time.
All of this is easily removed and the original drive shaft put back in.
I believe the rear end is a Dana 44 and should be able to acquire a kit for it. Just have to have a special drive shaft built.
Any thoughts or experiences are appreciated.
