Fuel problem redux. I thought I had everything sorted out, but not quite yet. Everything has been done or redone on my '63 Avanti R-2 R2658. Gas tank cleaned (not lined) check. Engine rebuild, check. Carburetor rebuild, check. Transmission rebuild, check. New fuel lines, check. Radiator rebuild, check. All new belts & hoses, check & check. Replacement gas cap with a hole drilled through the middle, check. Everything was fine until this past Saturday. It starts out strong and pulls fine up to 75 mph. After about 4 miles we were on a gradual uphill section & then it started to hesitate. I gradually was losing power but made it to the top of the hill. Turned around to limp home & tried one more hill, same hesitation and losing power. I was convinced it was a clogged fuel filter. Replaced that on Sunday & tried the same route only this time I was on the flat, no hill, not even two miles away & the same hesitation & gradual loss of power. 97 octane good gas, no ethanol, & I added the lead additive. Any ideas as to where to start would be much appreciated. Thanks in advance.
-got no smiles, cuz I can't do the miles
