My replacement frame has a pipe about 1-1 1/2"mounted just in front of the trans mount cross member and looks to be stock or very well built. Runs from one frame rail to the other and mounts with a plate bolted to the bottom of the frame. Now my old frame does not have this. Hard to see in the picture but it's the first thing you see behind the front cross member. Any one ever seen this and should I remove it. I can get better pictures.
gt hawk frame
Tags: None
There is NO way Studebaker would EVER have put a crossmember in the way of the Left Exhaust Pipe and the Bellhousing, you MAY have to unbolt it, sand/grind the Frame down and re-powder coat or Paint it.
On a Hawk, the Engine support Crossmember bolts in right about where that is.StudeRich
This frame came off a 62 gt out of CA. I picked up two cars in AZ and this one had no motor or trans but did have a auto shift. The other one was a 289 4 sp but 4 sp setup was long gone. It had mounts for traction bars but was just a bare frame and didn't have this pipe set up. So my guess is someone added it from a older frame.
Originally posted by swvalcon View PostThis frame came off a 62 gt out of CA. I picked up two cars in AZ and this one had no motor or trans but did have a auto shift. The other one was a 289 4 sp but 4 sp setup was long gone. It had mounts for traction bars but was just a bare frame and didn't have this pipe set up. So my guess is someone added it from a older frame.--------------------------------------
Usually there is a bolt BETWEEN the rails cross member. I have never seen an UNDER frame tube bolted there.Bez Auto Alchemy
