Hello, anyone out there have any ideas as to why my 1950 Champion's brakes keep locking up. Particularly, when I put the car in reverse. The brakes lock up for a while then release, if I don't apply the brakes again but as soon as I hit the brake pedal they lock up again. I've had the brake's master cylinder replaced as well as all four slave cylinders but sill the pesky lock up problem persists. Please let me know, thanks.
1950 Champion Brakes Locking up
If you dont have any free travel in the brake pedal your pushrod is out of adjustment.when replacing a master cylinder i always clean and re-use the old pushrod, it was right before so should be ok now,some times the new rod is generic and not quite right for anything, my experience. Luck Doofus
If your car has a "Hillholder" it may not be adjusted correctly.
If only the rear brakes lock up , that may be the problem.
If all 4 brake drums lock up , than you need to adjust the push rod on the master cylinder.
Robert Kapteyn
Read the following website for many answers.
