I just started up my rebuilt 185 with an aluminum timing gear and new crank gear and it appears to be causing a whine. It's quite noticeable and varies with the revs. I noticed it when I first started the engine and seated the rings. On the second start it disappeared. Then on third start it again was absent but after a 10 minute drive it was back.
Is this to be expected and how long before it goes away?
I installed a new oil pressure relief kit. The engine pegs the oil pressure gauge when it starts and then settles down to 40-50 lbs when warm and on the road. It gives about 10 lbs when hot and idling.
A fellow club member also installed an aluminum timing gear in his 259 Cruiser recently and it is also causing a whine.
Thanks
Graham
Thanks
Graham
