Today I took of with a buddy to a metalmeet regional get together.Walked in the door and local SDC member Henry Votel was welding and grinding on a set of truck fenders.I knew there was a '63 Avanti sitting in a shed on the property so Henry and I went to look at it.Car is completely disassembled,didnt see the engine or trans anywhere.Body tag read RO 3439.I couldnt find the serial number tag as I couldnt remember where to look for it. It is a 4-spd car and the owner claims it is a R2 car.Curious as to what info can be learned off the body tag.
Looked at a Avanti
Nothing much without the build sheet to match it to serial numbers. I'd guess it was built somewhere in the spring of 63.
JDP/Maryland
63 R2 SuperHawk (Caesar)
spent to date $54664,75
64 R2 GT (Sid)
spent to date $62,439.30
63 Lark 2 door
51 Commander
39 Coupe express
39 Coupe express (rod)
JDP Maryland
JDP/Maryland
64 R2 GT (Sid)
63 Lark 2 door
51 Commander
39 Coupe express
JDP Maryland
If engine and tranny are out of the car, the VIN TAG should have been visible on the frame rail. It is located on the right side just behind the wheel. That number tells it all.
See you in the future as I write about our pastsigpicSee you in the future as I write about our past
