View Full Version : A/C
andy w
04-06-2016, 07:41 AM
Im restoring a 55 e7 pickup. I would like to install air conditioning. Not exactly sure how to go about this. I was wondering if there was any type of under dash unit that would work. I don't really want to go the traditional route under the hood.
53k
04-06-2016, 08:41 AM
Check with Vintage Air (http://www.vintageair.com/). They specialize in such installations and have some very compact units for under the dash.
Dwight FitzSimons
04-06-2016, 10:37 AM
As far as I know ALL automotive A/C systems utilize a compressor driven by the engine and a condenser in front of the car's radiator, so there is no way to avoid the "traditional route under the hood." Think about it: Where else would you put the compressor and how would you drive it? And, where else would you put the condenser except in front of the radiator? That condenser gets rid of the heat that is removed from the interior of the car.
-Dwight FitzSimons
64V-K7
04-06-2016, 04:37 PM
They make electric compressors for Prius and other Hybrid type cars. That way you could put the compressor in the trunk if desired. However, they are NOT cheap..
52-fan
04-06-2016, 06:01 PM
Since the Studebaker C cab trucks don't have a traditional dash board ahead of the firewall the evaporator will be on the engine side of the firewall. IF you want to avoid an under dash unit. Back when my brother put a/c in his 57 Transtar no Studebaker specific unit was available. He cut off most of his glove box and mounted the evaporator there. He built a cover over the back of the Instrument panel to hide the evaporator and the back of the instruments. There isn't much of a way around this, but at least a Studebaker specific unit is available now.
jnfweber
04-06-2016, 07:44 PM
http://www.oldairproducts.com/catalog/
http://theairshop.com/gallery/
You might also be interested in these links. I am using The Air Shop in Orange, CA to replace the dealer-installed air conditioning in my '57 President Classic. I will probably have them install either the Old Air 200 or 300 under dash units, plus a new compressor under the hood and might be able to use the original condenser in front of the radiator. You can probably find a shop around Charleston who can put in either a Vintage Air or Old Air unit. I have attached a few photos I have acquired to achieve my installation.
Jett289
04-06-2016, 08:16 PM
Hey there Jack in Montana .. Where in Montana are you? Im north in Fernie British Columbia ..
That air unit that is square is so 70's looking and not attractive at all but the unit with the round
vents looks great .. Those old compressors were huge lol . Im wanting to put an AC unit in my GT hawk
but also retain the Supercharger unit .. Would love to see some pics if anyone has done this ??
52-fan
04-06-2016, 11:08 PM
One of our chapter members put A/C on his 64 GT Hawk with a supercharger years ago. It was a tight fit and he ran an extremely long belt. The small compressors they make now are an easier fit than the original style units, but there's not much room.
jnfweber
04-07-2016, 10:32 AM
I'm in Anaconda, just 22 miles NW from Butte. I will probably put the unit with round vents in my President. The one installed ...by dealer...? in '58..? looks like the square unit, but better. The round unit resembles those seen in the 63-66 Cruisers and the Avanti's. Lots of GT Hawks came from the factory with the round type under-dash unts.
53commander
04-07-2016, 09:10 PM
-Dwight FitzSimons
There are remote mount compressors available nowadays but they're not cheap http://www.jegs.com/p/JEGS-Performance-Products/JEGS-Remote-Mount-Electric-A-C-Compressor/3151133/10002/-1
Prius compressors operate on high voltage from the hybrid system which can be 200 volts on some years.
Sdude
04-07-2016, 11:23 PM
53001 This is Vintage Air's A/C unit that was specifically designed to fit the C Cab Studebaker trucks. Mine is a 49 2R, I'm not sure how different your dash is from mine but this unit fits right into the openings studebaker used for their heaters. I tried to post a picture from the under the hood side but am having difficulty getting it to post. Perhaps I will try again later.
Sdude
04-07-2016, 11:30 PM
53002 Under the hood view.
55 56 PREZ 4D
04-08-2016, 02:01 AM
andy w:
http://www.network54.com/Forum/23885
You may want to drop in on Studebaker Truck Talk.
Studebaker trucks only, they may have some ideas also.
