Tune Up 101 - The Vacuum Gauge - (link)
  • Engine: Tune Up 101 - The Vacuum Gauge - (link)
    A good read.....
    Intake manifold vacuum is a key indicator of engine performance. By measuring vacuum under different engine loads and conditions, you can track down problems within your engine and make the …
    (copy)
    TECH / TECH ARTICLESVac Visual: Quick Guide to Vacuum Gauge Readings
    Posted by David Fuller on March 31, 2016 at 11:58 am
    By measuring vacuum under different engine loads and conditions, you can track down problems within your engine and make the necessary adjustments or repairs. The key is having a reliable engine vacuum gauge and then knowing how to read it properly.
    piston rings? Bad head gasket?
    Find out what your vacuum gauge is trying to tell you below.
    I'm thinking "weak valve guides" was intended to be "weak valve SPRINGS" .
      The next question is where to find a 'good' vacuum 'port' on a stock '55 259 engine with a WCFB carburetor?
        My dad taught me how to read a vacuum gage in 1954, been using one ever since...
        Jim
          source
          If you've been doing it for that long, you must know where to plug the gauge in ????? Please tell me where you are getting a good vacuum read !!
            http
            This picture might be hard to see it's the best I could do. My engine is a 232ci, on my intake manifold drivers side in the back is a hole with a pipe threaded plug. A long time ago I removed the plug and installed a hose with a plug. When I want to adjust my carb or timing I pull the piece of hose off and hook up my vacuum gage...
            Jim
