My 58 silver hawk is finally in the garage having the turner brake kit installed. On the car now are 14 inch mustang gt rims, which I am going to change. I am thinking of putting 15 inch crown vic rims on but wonnder will studebaker full disc caps fit those rims? I would like to get back to studebaker caps . Also reviewing old posts did not see any consistant choice of rims when converting to turner kit.
rims and caps
Since I am yet not sure whether the original wheels of my 54 Champ HT are any good (much rust) I am also interested in possible substitutes that are as original as possible.
Does Crown Vic refer to Crown Victoria Ford wheels? What dimension details are needed to fit Studebakers?
Mine was equipped with Regal Wire Discs but I prefer the dog-dish style (if they are available .... on ebay?).
Thanks for letting me step in on this question!
The dog dish caps will not fit the Ford wheels. If there are raised lugs for small caps, they will not be correct to mount the Studebaker cap. You may be able to force it on, but it will distort the cap. If there are no raised lugs for the caps, you may be able to add VW hubcap clips to the wheels. Just work carefully and make sure they are centered.
Originally posted by austrian View PostSince I am yet not sure whether the original wheels of my 54 Champ HT are any good (much rust) I am also interested in possible substitutes that are as original as possible.
Thanks for letting me step in on this question!sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
I couldn`t find 15" crown Vic wheels for my 51 champion starlight with a turner disc set up so used Ford 15" Ranger Factory steel rims instead.
when I got the wheels they were already fitted with 225/75/15 tires which I was told were to big !!!!
Here they are fitted with the 225`s they fit perfect to the hub and clear the caliper too.
Under the rear fender the tire is about 2 1/2" to 3" away from the chassis and about 2" away from the fender outer lip
The fronts may restrict the turning lock a little due to maybe rubbing on the inner fender on full lock but a lock stop would stop that if I chose to leave the 225`s mounted
I will opt for the correct full Studebaker covers
Geoff
Thanks for letting me step in on this question!Skip Lackie
The Ranger wheels shown on "fiveftsix" post can be found on:
Ranger 93-09
Explorer 93-94, 96-00
Mountaineer 97-01
Mazda B2300 96-03 [the Mazda was a rebadged Ford]
Studebaker used 3/4" lugnuts, 1/2"-20 threads.
Ford used larger lug nuts. You will need the larger lugnuts.
Dorman wheel nut #611-121.1 is 1/2"-20, right hand thread, 13/16" hex.
Dorman wheel nut #611-031.1 is 1/2"-20 left hand thread, 13/16" hex.
A couple bucks a piece.
In stock usually at NAPA or a good auto parts store.
DO NOT use the stock nuts as they will wallow out the hole.South Lompoc Studebaker
