Car: '53 C w/289 & Edelbrock on cast iron intake
Starting to address my fuel issues - they are minor, but annoying.
One of the issues is when the engine is hot and I park somewhere, when I come out after 15-20 mins or more, the fuel seems to have evaporated out of the float bowl and I have to crank the engine over several seconds before the bowl gets refilled.
I'm generally a Holley guy, as I don't care for the Edelbrock/Weber/Carter style carbs as I find them finicky to tune well - don't want to get into a debate on this, just a data point.
One of the things I've noticed on the two cars (one prior non-Stude) with Edelbrock carbs is this heat soak issue. It wasn't as bad on the other car, but it had an aluminum intake. I'm assuming the cast iron is holding the heat a lot longer and 'boiling' the fuel out of the bowl.
While I realize I could pull the intake and block off the heat riser, I figured my first step in addressing this would be to put an insulating spacer under the carb. There's currently a 1" thick aluminum one. I had a 1" plastic one and popped the carb off to try it this weekend. To my frustration, the Stude intake uses the small bolt pattern on the 4-bbl intake and this particular spacer only had the wide pattern.
A couple new gaskets and everything was back. Figured I'd search for a spacer with both sets of holes, like most of the gaskets have. Well, only found one brand, transdapt, that has insulating spacers with both bolt patterns. The problem is, they want $135 for it!!
So, short of fabricating one on my own, does anyone know of another insulating spacer (I don't care about material - plastic, phenolic, teflon, what-have-you) that has bolt bolt patterns. Oh, and I will only use a ported, 4-hole spacer (I know..getting picky now).
Any suggestions before I start collecting bottles to save up for a spacer from transdapt?
I had wanted to avoid pulling the intake and blocking off the heat riser, but that may be the ultimate solution and since I live in the south, won't be much of a driveabiiity issue.
