View Full Version : Champion engine serial #
Robert
03-18-2016, 07:10 PM
Can anyone tell me the year and cubic inches of serial #I223349?
Studebaker Wheel
03-18-2016, 09:54 PM
1953 Champion. Six cyl 3 X 4" 169.6 c.i. 7.0 comp ratio, 85 H.p. at 4000 rpm.
Robert
03-18-2016, 11:59 PM
Thanks for info,i was hoping it was a 185 c.i.
Dwain G.
03-19-2016, 01:27 AM
Seems to me it should be a '57 engine, a 185. Look for the casting number on the side of the block near the distributor. 533870 was used 1955-58.
Robert
03-19-2016, 11:54 AM
Thanks for the info Dwain.I thought it was later than a 53 as I have a chasis manual for 53/54 and the beginning #s for 54 are quite a spread from what I've got and I know 54 was a slow year.Checking the casting # indicates a 185 as it is 533870.What are the differences with the 185 block?Probably clearance for the longer stroke?
Dwain G.
03-19-2016, 02:48 PM
Based on the original block, but with some major changes. The main line was lowered 3/16" in the block, and main bearings were increased in size. For con rod clearance the cylinders were notched at the bottom, and the piston skirts were notched on each side.
