View Full Version : Can-O-Worms
wlfrench
03-17-2016, 08:15 PM
I have been wanting to replace the trunk pan on my GT from day one but the cash needed to pay someone to do the job always seems to go to higher priority needs. :( Then a few days ago the Harbor Freight catalog shows up with a 170 amp mig welder on sale for $169.95 and I start thinking that there's no reason that I can't do the job myself. Now I have never welding a thing in my life but I work in a shop with a bunch of guys that weld all day long to get tips from and we have all the equipment right there to practice with so why not. :rolleyes:
So, then I get to thinking, well I got to put the GT up on jack stands and drop the gas tank so I might as well get that cleaned and lined while I'm at it. And when I cut the pan out I'll have lots of room to get at the leaf springs, which are shot anyway, so I might as well get them re sprung. With all that room to work with the springs, gas tank and trunk pan all out of the way its only logical to go ahead and replace all the bushings and add the rear sway bar for good measure. All of this doesn't even take into account the hidden stuff I'm bound to find once I get started. :ohmy: Once she's up on the stands there's no point in letter her down again until all the work is done so I guess she'll be off the road for most of the summer and into the fall. All of that from one Harbor Freight catalog.
63t-cab
03-17-2016, 08:54 PM
It's a shame You can't enjoy this Summer/Fall driving. then put it up for a Winter Job :(
63 R2 Hawk
03-17-2016, 08:55 PM
Heck, might as well pull the body off the frame while you're there and, while it's easy to get at the motor and trans, might as well rebuild all that too, and then there's......... That's what happened to me, anyway. Beware of creeping restoration elegance..! :)
garyash
03-17-2016, 09:40 PM
While you can still drive the car, be sure to power wash the underside thoroughly. Lying on the creeper with grit falling in your eyes as you try to work on the underside of the car is no fun. Ask me sometime how I know this. Try to do all the welding from the top side 'cause hot metal droplets down your sleeve from trying to weld overhead is even less fun.
GrumpyOne
03-17-2016, 11:32 PM
Regarding cleaning the gas tank, if it isn't giving you problems, I'd leave it alone. But if you do have a cleaned, (local radiator shops can do that), I would opt out of "lining" it. I've seen way to may complications from such and that includes the pros like RENU..
Mrs K Corbin
03-18-2016, 07:03 AM
If I had it to do over again, I wouldn't have bought a Harbor Freight Welder Mig.....
it'll last just about thru the trunk pan job you have and then become increasingly more difficult to use...
The transformer is ok, but the wire feed goes to pot...
It's not the the feed device or the rollers, however I've adjusted my rollers as tight as I can.
I believe it's the tube inside the "hose" that goes to the welding handle. And yes, I've replaced the tips.
Hope you have better luck than me....
studeclunker
03-18-2016, 01:32 PM
I've run into quality issues with Harbour Freight tools myself. I always get the maintenance contract. They've replaced an item sometimes four or five times before I finally get a decent one. No hassles, no whining, they just replace it. Just remember to get a new contract with the replacement.;)
thunderations
03-18-2016, 02:49 PM
If you have buddies at work that weld, why not entice one of them to weld the trunk for you. They probably have much better equipment then a flux wire feed from HF. I hate the flux wire. Always chipping the slag and the cost of the wire.
GrumpyOne
03-18-2016, 04:16 PM
When it comes down to welding gear, the saying, "You get what you pay for," takes on a new meaning. MIG welders for sheet metal are of "short arc" technology in that the process must be interrupted consistently to eliminate burn throughs and maintain puddle flow. They are low penetration and precision machines. The term "precision" often is not applicable to Chinese imports as is "cheap."
Better to find a good used American brand as most of these were built like tanks seldom having issues...
Kurt
03-18-2016, 07:30 PM
I had a cheap mg from harbor freight for years. It was ok, but I always had problems making decent welds. I figured it was the fact that I don't weld often. About 2 years ago I bought a Lincoln 210 power mig welder. I found out that I was a better welder than I thought......
Buy a good welder, or find a friend who has one that you can rent/borrow.
Neil
03-19-2016, 07:02 AM
I have to agree with 63-tcab about a winter lay-up . I saw your Hawk at York last Friday an took a couple pics of it and it is really a nice car . I would be driving her all over the place this summer spreading the Studebaker love . You have a really nice car,love the 4 speed .
JoeHall
03-19-2016, 08:41 AM
I agree with Neil. Just drive it. Unless the rear corner supports are totally gone, that trunk can wait for many years. Just insure there is sufficient clearance between the floor and gas tank, so the floor does not rest on the gas tank. If that is the case, you can simply shim the mounts and drop the tank 1/2" or so. Then, put some kind of reinforcement in the floor, to spread the PSI of any load you carry. You can also lay a 1/4" of fiberglass in the floor, and get another 10 years out of it.
Just my two cents, but it really depends on priorities. I place a high priority on just driving them. Don't need a show car. Your priorities may be different.
TWChamp
03-19-2016, 09:45 AM
I totally agree with #5 and #6 and the rest of the replies. If you can't afford a new name brand welder, then look for a good buy on a used one.
Right now I'm stripping the liner out of my gas tank that someone did when they restored the car. It was coming off and plugging up the fuel line. I would never line a tank.
wlfrench
03-19-2016, 12:31 PM
Thanks for all the good replies. I know that HF welders and not the best but I have seen good welds done with them. That, I'm sure is due the the skill of the person doing the welding. I consider the HF welder to be a throw away item and replacing the trunk pan was the only job that I wanted to do. I would probably put it on CL when I'm done to try to get a couple of bucks back. A guy at work has a little Miller 110 volt for sale for a $100 bucks but I don't know if that would weld deep enough. Thanks Neil for the kind words. I wish I could have talked to you while I was there. Please post the pictures that you took. My GT is a nice 10 footer but really needs some help with the front and rear suspension. The rear passenger side sits about an inch and a half lower than the drivers side and all the bushings, front and rear, need to be replaced. With the trunk pan replaced the underside would than be pretty solid and would make me feel much better. As it is now its always in the back of my mind. It might not take me all summer depending on how much other stuff I decided to do at the same time but the springs are a must and with the gas tank and trunk pan out of the way it would be the perfect time.
studebakerkid
03-26-2016, 04:54 AM
You aint gonna be a good enough welder to weld in that trunk pan in years. I can weld well but get the shakes and on that thin stuff the shakes does not cut it. I bought a Hobart 180 and when I need thin stuff welded call my nephew and the welds look so perty......The replacement left front fender for the 54 wagon is sitting in my shop with replacement metal all bent to fit waiting for my nephews perty welds inside an out right now. Once you start welding with wire you will like using it so you might as well get a good welder. Ask your workmates if one of them will weld it once you get it all set up. Does your shop have days when you can work on your own stuff? If so you could have the car prepped sitting on your trailer for a quick after work weld job.
DEEPNHOCK
03-26-2016, 06:22 AM
Sometimes, the shakes can make for better welds. Just work on the timing of your personal shake :rolleyes::D
<snip> I can weld well but get the shakes and on that thin stuff the shakes does not cut it. <snip>
DEEPNHOCK
03-26-2016, 06:29 AM
As far as welders go.....
Just pay close attention to the 'duty cycle' of the welder you are using.
This Harbor Freight Mig welder has a 20% duty cycle.
That means for every 60 seconds of welding, you have to let it cool off for 108 seconds.
Think about that. You can weld for 12 seconds of every minute.
http://www.harborfreight.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/i/m/image_24744.jpg
Specifications
Name
90 Amp-AC, 120 Volt, Flux Cored Welder
SKU
61849
Brand
Chicago Electric Welding
Amperage (amps)
20
Duty cycle
20% @ 90 AC amps
Maximum amperage output (amps)
120
Maximum Diameter
0.035 in.
Minimum amperage output (amps)
60
Minimum Diameter
0.030 in.
Open Circuit Voltage
27
Quantity
1
Thermal Overload Protection (y/n)
Yes
Weldable metals
Mild, low alloy steel (not suitable for aluminum or stainless steel)
Welding capacities
18 gauge to 3/16 in. thick (0.047 in. to 0.187 in.)
Product Height
14-3/4 in.
Product Length
14-1/2 in.
Product Width
8-3/8 in.
Shipping Weight
37.85 lb.
Size(s)
90
Accessories Included
spare contact tip, hand-held face shield, wire brush / chipping hammer combo, spool of flux core wire
SN-60
03-26-2016, 09:02 AM
"It's a poor workman that blames his tools"..........;)
Mrs K Corbin
03-28-2016, 06:56 AM
it's easy to blame harbor freight stuff.... I've got some.
some is ok, some is poor. I absolutely love their 4" angle grinders, but remember to remove the screws around the gearbox and add lock-tite.
most of their electrical tools are garbage. Including the hobby mig welders.
I still buy some stuff from them, however. Usually stuff that's light duty.
M15 Trucker
03-28-2016, 07:45 AM
The Duty cycle is based on 10 minute cycle, so if its a 20% duty cycle at 90 amps, then you can weld for 2 minuets strait then cool for 8. Keep in mind that's a full on continuous trigger pulled for 2 minuets, not start, stop, move and start again in the 2 minuets. So take into account setup and moving from one weld to another as cooling time. it tends to stretch out the duty cycle. Also, the duty cycle will increase as the amps are lowered like you would for sheet metal welding.
52hawk
03-28-2016, 08:40 AM
Nobody has mentioned the worst thing about this HF welder. It uses flux core wire and not gas. Mig welding really relies on the argon and co2 to produce a good weld. For a beginner to try to weld with the flux core,I think would be very disappointing.
swvalcon
03-28-2016, 11:24 AM
eastwood has a good price on a small 110 unit that i'am also looking at. go on their web site and give it a look.
thunderations
03-28-2016, 12:03 PM
Check my post, #8, but thanks for bringing it up again. Flux rhymes with sucks and that's a good comparison. Welding sheet metal takes decent equipment and argon/co2 helps cool the weld.
