I hastily bought my first Studebaker, a 1962 Champ, and may already be regretting it. After a couple short drives I decided to take a longer drive. Cruising at 50mph, I stalled out following a loud ping sound. I was able to nurse the truck home and found the following as shown in the pictures. A large puddle of oil was below. What did I get myself into??
62 Champ
The dreaded cast iron heart attack has struck. look for another motor, that one could be repaired but at what cost? There are still OHV champ sixes for sale. Looks as though you have thrown a rod right through the block, bad luck. Doofus
Yep that engine is toast. You could do a Stude transplant or a Brand X. The 20R in one of mine works just fine.If you car is ugly then it better be fast.....
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
63 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MC
45 Agricat
67 Triumph T100
66 Bultaco Matadore
If you were closer, I would give you a spare ohv six to get it out of my garage That said, I'm with the fellows above, find a good 259 from a parts Champ or a Lark and go in that direction.
Jeff T.\"I\'m getting nowhere as fast as I can\"
The Replacements.
Originally posted by Jeff T. View PostIf you were closer, I would give you a spare ohv six to get it out of my garage That said, I'm with the fellows above, find a good 259 from a parts Champ or a Lark and go in that direction.
Jeff T.Last edited by JoeHall; 03-27-2016, 01:11 PM.
Just drove our 63 Daytona to Tucson March Madness and back, about 400 miles, at highway speed of 65 to 75 MPH and it performed very well. Not going to get huge acceleration to pass a truck or anything, but very decent to cruise with. That's with an automatic behind it. I expect a stick would be more responsive. OH, and that's with the original, crappy, single barrel carb.
Originally posted by JoeHall View PostAt 50 MPH, you were pushing the little six too hard.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
Now while I advocated for a V8 transplant, my 170 with overdrive and a 4:27 rear would cruise at 60-65 with no worries...though I'd have to drop out of overdrive on hills and that 6 made quite a racket. I now run a modified OHV6 with a 185 crank and mild cam, and it runs at 80 with room to spare...but with a track suspension, it was rather scary. I can run at 70 and not need to kick out of overdrive anymore.
Still it is no V8, and a V8 swap would still be cheaper than what I built. And Bob is right, for a '62 and earlier, it's more than just the engine, it's bellhousing, flywheel, clutch and transmission too, and probably driveshaft as major parts. The 63 and 64 used the V8 bellhousing, and the transmission would work too, though it might be short-lived behind an 8Ron Dame
'63 Champ
