Saturday, I went to the warehouse to get my 48 commander out of storage. The 6 volt battery was weak, not enough to turn the starter. so I took it home and gave it a 50 amp charge for about and hour or two. Returned to the storage warehouse put it in and fired it up. Heading home she stalled and I let it sit for a few minutes then she started again.. I was letting it idle, with the heater on when passerby wanted to talk about the car.. few minutes went by and I got on my way again.. all of a sudden she stopped. I smelled smoke lifted the hood and I had a wire coming off the top of the starter about a 14 gauge red hot smokin... I digress the volt gauge was banging negative (not charging when i was driving) now I have the burned wire and can not start. My question is if I replace the burned wire and install a new voltage regulator after polarizing it... should she run. I also found tonight that my battery is not holding a charge so I am also planning on getting new battery tomorrow. Is there a fuse further up the line behind the dash I need to find? Did the slightly discharge battery lead to this problem? Might the contacts in the 67 year old voltage regulator have fused or stuck closed to cause this problem?
I am trying to figure this out before I put in the new voltage regulator and new battery.
Any ideas would help.. I am a newbie...
