Last Friday at York I was lucky enough to find a nice late '62+ T-10 4-speed transmission with yoke and shifter for a good price. Also got a "big clutch" flywheel, clutch disk, and pressure plate for a great price. I already had a big clutch bellhousing with the right bolt pattern for the T-10. So, I have most of what I need to convert the 3-speed w/OD in my '54 coupe to the 4-speed. My question is what to do about the driveshaft. Will the stock 2-piece shaft be the right length to use with the T-10? If I have to switch to a 1-piece shaft, would any '58 or later Hawk 1-piece shaft fit? I realize I would have to remove or modify the cross-member that supports the center bearing for the 2-piece shaft.
Thanks.
Thanks.
