Anyone know what the width is on the gt hawk spring bushings? I know the diam. front is 1.5 and rear are 7/8 but what about width.
Tags: None
Studebaker used SAE Fine Thread fasteners on many things, but mostly things they did NOT want to FALL APART!
A Fine Thread takes at least Twice as long to work/vibrate it's way off, than a Course thread Bolt and Nut.StudeRich
Fine threaded bolts are stronger than the equivalent coarse threaded bolts in both tension and shear since fine threaded bolts have a slightly larger minor diameter.
Cliff54 Commander Coupe driver
53 Commander Hardtop project
SE Washington State
Originally posted by cliffh View PostFine threaded bolts are stronger than the equivalent coarse threaded bolts in both tension and shear since fine threaded bolts have a slightly larger minor diameter.
Cliff
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Originally posted by 52 Ragtop View PostA grade 3 bolt is a grade 3 bolt, as is a grade 5 or 8 bolt, threads have nothing to do with the strength of a bolt. I "think" the spring bolts are all grade 5
Jim
http://www.katonet.com/article/coarsevsfine.html
However, I agree with StudeRich, Studebaker probably used fine thread bolts because they have less tendency to loosen under vibration.
SE Washington State
If you look closely you will find that the bolt is in the upper hole on the Pass. side and the lower hole on the Drivers side. That is because you have the Battery and Driver on that side and if you get a 200 lb. driver you need it.
