Does motor oil have a shelf life? The reason I asked is that I have an unused 5 quart jug of Walmart synthetic oil that I can use in my 1995 Dakota for the next oil change. It has been sitting in my garage for at least 15 years.
Oil Shelf Life
There may not be a shelf life, per se, but what happens is the compounds might separate over time, but I would think shaking it up should take care of that. What definitely changes, is the service classification. I think that as long as the service classification is at least that of the truck's requirements, you should be good to go.
If you're not sure, use it in the lawn mower.Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
Originally posted by Gunslinger View PostThere may not be a shelf life, per se, but what happens is the compounds might separate over time, but I would think shaking it up should take care of that. What definitely changes, is the service classification. I think that as long as the service classification is at least that of the truck's requirements, you should be good to go.
In my opinion, there is less chance of a problem with a synthetic than with real oil.
I do agree that the additives are where a problem may lie, if they might break down over time. Storage conditions may play into this. Is the garage climate controlled?
With all said, I would not use it in any vehicle that I cared about.Gary L.
Most of the oil companies say that the shelf life of engine oil is 5 years. That may be a blanket statement which covers the worst storage conditions. I would think if oil is stored in a climate controlled area, the shelf life could be quite a bit longer. I know with piston aircraft engines, the oil has a use by date stamped on the bottles which is 5 years. Bud
If you store it in oak barrels the taste and color improves greatly after eight years.
Lark Parker --Just an innocent possum strolling down life's highway.
I like the fact that they have rental barrels available!
Originally posted by Lark Parker View PostIf you store it in oak barrels the taste and color improves greatly after eight years.
http://www.lexingtoncontainercompany...d-Barrels.htmlHTIH (Hope The Info Helps)
I had the same dilemma as I have a lot of oil stored on shelves in the original cans(some both metal and cardboard). I spoke with an expert who has his own brand of specialty oil for our classic cars with more ZDDP than standard. He told me that as long as you turn the cans periodically the additives will stay mixed accordingly. Of course do not use them in newer vehicles as Gunslinger states because their requirements are entirely different but for our oldies, no problem. For example, Dodge's SRT 6.1L requires only Mobil 1 Full Synthetic 0W40. Also as Gunslinger states, use it in equipment not so special.
Bill
Well, my little Dakota has the 2.5 L. SOHC 4 cylinder engine and is the vehicle I use for most of my running around town. The engine was rebuilt 3 years ago and has been fairly dependable. After reading the Mobil Oil information I think it will be okay to use the oil in question. I usually try to change every 3K. miles. Thanks for everyone's input.
A couple of thoughts: I would doubt that the petroleum portion of the oil would be affected but the polymers that are used to modify viscosity could be affected. Nothing good happens when polymers coalesce unless they are being used for coatings et. cetra and that's probably what is collecting at the bottom of the container. The worst that, I would expect to happen, is the viscosity would not be as advertised.
The viscosity change may be acceptable in older cars but not the new ones.
A quick reason, I belong to a couple of Ram Truck sites and one topic of discussion is oil viscosity. Ram suggests that 0W20 wt only be used in the newer 5.7 Hemi's and the folks on the forum seem too agree that if you go out of that viscosity range that the system senses the viscosity differences and changes engine control parameters to account for the change. And generally not for the better . Just the messenger here but, personally, I'd just take anything over five years or longer to a local auto store for disposal and use new, but that's just me.
2 years ago I bought 140 quarts of 10W30 oil a guy had stashed in a storage unit that came from a c-store he had closed 15 years ago.
I've used it in all 4 of my vehicles and had no incidents.
I will add that the my vehicles have odometers that read from 193,000,218,000,248,000 and 336,000 miles so they are nowhere near new.
Perhaps with that many miles they are happy to have any oil at all in them.
I also bought 10 cases of 20W50 and the drag racers who bought some from me have not had any issues.
Could be dumb luck,I don't know.Mono mind in a stereo world
I had to get rid of some Sta-Bil...because it was out of date.
Yes, Irony is alive and well in America, though many don't seem to get it.63 Avanti R1 2788
1914 Stutz Bearcat
(George Barris replica)
Washington State
Originally posted by lark55 View PostDoes motor oil have a shelf life? The reason I asked is that I have an unused 5 quart jug of Walmart synthetic oil that I can use in my 1995 Dakota for the next oil change. It has been sitting in my garage for at least 15 years.Paul Johnson, Wild and Wonderful West Virginia.
