I'm slowly but surely working on my '57 289 V8, and a few weeks ago had discovered the machinist assembled the rods backwards on the right bank side.
Have not had time to get back in and 'un-do' and 're-do' but spent some time looking at it today to be sure I have orientation right for both rod, piston and piston pin screw... (have hypereutectic pistons with NO slot, and arrow for orientation, no 'slot in skirt' to reference).
After studying the shop manual, it appears to me that the original Stude pistons had the slot in the skirt facing the outside of block for one bank, and facing towards the camshaft for the other bank.
One cut-away view of the whole engine shows the slot on Left side of engine facing OUTSIDE, away from camshaft.....
(other text indicates the Right side pistons have the skirt with slot facing towards the camshaft, based on photos and orienting with the connecting rod numbers..). Yet all of the piston-pin nuts are supposed to be on the slotted-side of piston; which means one bank has those pin nuts on outside, the other bank has the piston-pin nuts facing inside. I would think you would want the nuts on the "opposite, symmetrical" sides for balance, and that you'd want the skirt slits the same direction (which was the case for my Model-A and Model-T pistons).
I have not pulled them and disassembled and reversed the rods yet, and I don't have 'slits" in my new pistons, but I plan to assemble the piston pin nuts as manual seems to indicate; outside facing on left bank, inside-facing on right bank..... Odd (assuming I've finally got it right).
And what is different with the newer pistons that they have an arrow for which side faces front? They don't specify which SIDE of the engine to install them in, so seems they should be identical except for the arrow. Is that just an assembly aid for the mechanic after he has rods and such correctly assembled (which ARE different side to side?). In that case, maybe I don't need to disassemble my pistons, simply spin 180 deg to get the rods oriented correctly, and let the arrows face backwards; less monkeying around with the now-oily assembly, less risk of debris. Otherwise not afraid of a little work....
Am I right? And if so, anyone explain the slits in the skirts and why they wouldn't be installed originally 'symmetrically", slots facing out, or in, on both sides??
Thanks!
Thanks!
