I have a 700R4 in the Hawk and have been using a totally ugly B&M floor shift unit. I would like to go back to the column shift and am wondering if anyone had used the Lokar column shift kit and if so there were any problems. Any input would be greatly appreciated.
column shift linkage
Here's a pretty good video that shows someone actually installing the lokar unit on a GM column. If you posted a pic of the lower part of your column I might give you better advice. I know I had to swap my column shifter lever because my original column had a cast iron lever. A metal (steel) lever gives you more option. Don't know what your column has for a lever??
treblig
I kept the column shift in the 63GT, when converted to a 700R, but it wasn't easy. I used the OEM column and shift lever at the bottom, but used a LoKar universal adapter on the tranny end. It required a bit of yankee engineering, but I do not recall the specifics. Bottom line, it is do-able.
