I've just recently rejoined this forum after a multi-year absence. Maybe I should have started this new thread in "Tech Talk" Forum. My '51 2R5 half ton pickup is ready for reassembly. I need parts catalogues, mostly for body improvements, since I have already thoroughly modernized the chassis and drive train and steering and brakes to meet modern highway demands. My most immediate need is mounting hardware (bolts, washers, cushions, spacers/shims, and nuts) to mount the cab to the frame. Where do I go in this forum to zero in on sources for body parts and cab mounting hardware? I was told I could find helpful links to sources like this but I've not stumbled upon those links yet. Thanks.
Parts catalogues for chassis and body
The parts book which is available at Studebaker International will tell you what you need exactly, otherwise, its not hard to figure out the size bolts to put through the holes in the floor so they go through the frame's cab support brackets. The truck has rubber spacers sitting on top of those support brackets. I understand Studebaker used tire sidewall material but you can also go to a Farm Fleet store and get a little conveyor belt material.
More Truck help available here: http://www.network54.com/Forum/23885
JSI was STUDEBAKER, when STUDEBAKER wasn't "KOOL".
The body mount hardware is listed in section 2403 of the 49-56 truck parts book. All four of the cab-to-frame mounts are different and use different length bolts. One is bolted solid and the other three have small heavy springs to allow the cab to flex. There are a set of those springs for sale on ebay right now.Skip Lackie
