Well, we finally got some rain here in So Cal. The other day I needed to run some errands & took the 62 Champ out. When I turned on the wipers they swept 2 or 3 times & then stopped. My first stop was only a few blocks away so I continued on & went in for almost an hour. When I came out & started back turning on the wipers worked & continued to work, just like they are supposed to. Then yesterday afternoon it was time for the 62 Cruiser to go for a spin. Turned on the wipers & 2 or 3 sweeps & stop. This time I needed gas that was 4 miles away so I continued on VERY carefully. After getting gas I turned on the wipers & they worked & didn't stop. Now both vehicles have been driven pretty regularly but the wipers weren't used for some time until now. Has anyone else had this occur to them? Any ideas of what could have caused this situation on 2 vehicles?
Wiper motors & "El Nino"
Electrical: Wiper motors & "El Nino"
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 autoTags: None
When I lived in the California desert, sometimes the rubber wiper blades would crack, but go un-noticed for who knows how long, till I'd suddenly need to turn them on one day. Then, I'd have an, "oh crap" moment, till I could get to a FLAPS.
When I first got the 62 GT, now over 30 years and 300,000 miles ago, I disassembled the wiper motor entirely, cleaned and lubed everything. Today, it still works as good as ever.
So maybe just a little TLC on yours is in order. Also, don't forget new blades, especially if you cannot recall the last time you changed them.
Sounds to me that the switches might have a little dirt/corrosion on them. Turning them on and off might have cleaned them enough to work. Strange that it happened to two different cars in the same way, but why not. You might try spraying the switches with some contact cleaner.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
I have written about this before as the symptoms sound the same. The two brass contact strips inside the rotating electrical assemble on the wiper motor have worn. They heat up, and like a thermal switch/breaker warp from the heat and bend away from there dragging circular course. Once lifted the wipers stop at whatever position they find themselves at. Once cooled down the cycle starts again. The remedy is to either replace them or replace the whole wiper motor assembly. You will find the brass contacts under the circular cap where the wires are soldered at the wiper moror. I will try to find the post that has more details but no promises.
Len
Originally posted by Skybolt View PostI have written about this before as the symptoms sound the same. The two brass contact strips inside the rotating electrical assemble on the wiper motor have worn. They heat up, and like a thermal switch/breaker warp from the heat and bend away from there dragging circular course. Once lifted the wipers stop at whatever position they find themselves at. Once cooled down the cycle starts again. The remedy is to either replace them or replace the whole wiper motor assembly. You will find the brass contacts under the circular cap where the wires are soldered at the wiper moror. I will try to find the post that has more details but no promises.
Len-------------------
Daddy always said, if yer gonna be dumb, you gotta be tough & I\'m one tough sumbiatch!
Well not too far from you on RT.#35 in Middletown, NJ is Bobby's Auto Repair...he may not be an "authorized" dealer....but he sure can fix that Avanti!!Originally posted by mch View PostI too have experienced this problem, an internet search has yet to find a local authorized Studebaker dealer that will repair under warranty.
