Hi, I purchased an aluminum cam gear, and associated new crank gear. My original crank gear got RE-installed by the machinist (never thought to ask him to leave it off...) but I should be able to get that off with a gear puller, not planning to reuse it....
But I want to make sure I install the new gear properly and completely seated!!!!
By the way, I've not seen a gear " black-coated", not sure if heat-treatment or a coating? Is that anything special ? Will heating the crank gear to 350F in oven like I've seen recommended here have any negative effect on that coating, if it IS a coating? Probably not considering engine temps, but... I'm used to bare steel gears). My camshaft was completely redone by a camshaft, and THAT is black and supposedly "coated', thus wondering, otherwise probably wouldn't have given it a thought.
My installation plan was just like ring gears on a Model-A, heat up the new crank gear to 350F or so, run it out to the shop and drop it on. Then if it still doesn't go all the say, any reason I can't gently tap it on, with a pipe or other "uniform" tool, until it is firmly seated all the way?
(with the crank vertical on the bench, supported on a wood block.....?)
Appreciate advice; searched and read many a post but besides the heating to 350F, didn't find any posts about installing this gear (except with the nice but not in my shop Stude tool).
I also wonder, if my original crank gear is "ok" (not perfect, but running against a fiber gear all these years, not a lot to wear...) if there is any reason to simply leave it in place and use the new one for a paperweight at work? Just seems right to pair a new ALUMINUM cam gear with a new crank gear, ..... but also seems there would have been more posts and questions on the Forum if it typically is replaced. Maybe I'm overthinking it and you just (gently) whack it on, like a lot of other gears there are no special tools FOR......
Thanks guys!
Barry
Thanks guys!
Barry
