Starter Bolts?
  • Starter Bolts?
    I'm finally at the point of reassembly on my 53 Starliner and am getting together all the parts I've scattered and stuck in various places. I can't find the bolts that hold the starter on. My engine is a 289 with a truck manual transmission bell housing. Does anyone have a set or could point me to a source? Thanks,
    Darryl C. Lewallen Clarkesville, Ga.
    Google is your friend
    JDP/Maryland
    63 R2 SuperHawk (Caesar)
    spent to date $54664,75
    64 R2 GT (Sid)
    spent to date $62,439.30
    63 Lark 2 door
    52 Starliner
    51 Commander
    39 Coupe express
    39 Coupe express (rod)
    JDP Maryland
      The Truck Clutch Housing requires special extra long starter bolts, same diameter as the car and also with a long "shoulder". The Truck housing also will require custom made engine mount brackets to install in a car.
      Studebakers Northwest
      Ferndale, WA
        Rich, I assumed so much on the brackets, Do you have any of these bolts? The thickness of the bellhousing where the bolts go through is 3" and 1 1/2" approx. Thanks all,
          Sorry no stock, they are very hard to find. You will have to make them from a longer bolt to get the long shoulder, and cut them to size.
          Ferndale, WA
